- 12 Sep 2007
First look at a Nexus 4 this morning, lovely phone but there was a really strong yellow tint which didn't look good at all, especially compared to my Butterfly.
Does anyone else have a squeaky nexus 4?
When i push just to the left of where you insert the mini usb cable, there a squeak, like it hasn't been screwed in all the way.
It's nothing major, just a little annoying knowing it's there.
Earth[Tera].bin;23893237 said:First look at a Nexus 4 this morning, lovely phone but there was a really strong yellow tint which didn't look good at all, especially compared to my Butterfly.
Anyone know an app that can manage profiles?
Ideally, i want it to do the following:
- Switch on Wifi, Turn on volume and Vibrate when i get home.
- Switch off Wifi, turn off sound and enable vibrate when im in the office?
Don't want to use a location aware app as i never turn my GPS on (only when using navigation).
Tasker can use location "contexts" without using GPS. It uses cell masts and wifi triangulation (AFAIK).
Yeah, mine does that.
The screens on the Nexus 4's often could do with colour recalibration unfortunately.
I've gotten used to mine but I'm reminded how "drab" it looks by comparison every time I use a friends phone or my old Xperia S, which had the best screen in the world![]()
Every now and then my swipe down action for notifications or quick settings fails. After that I cannot get it to work unless I reboot the phone. Just me?
rp2000
Buy some NFC tags.
rp2000
I usee Llama to do that.
...Where could one buy NFC tags from?
Downloaded it and it seems to do what i want BUT i cant figure out how to enable/disable wifi when i select a particular profile.
I've created Profiles which was easy enough but they just control the Sound/Vibrate functions of the phone.
What i want to do is pair those Proflles now with Events that occur when i select those profiles. For example when i select Profile "X" wifi turns off/on.
Thats the bit i cant figure out.
rp2000
Go to the events tab and you can do that![]()
