My IceQ takes the voltage from AB Tommy
Yours the BE?
Yes, it's the BE, the core doesn't need voltage, but the memory needs a touch more then it oc's well.
On the presumption your Ice-Q is the normal bios, do you have working vrm temps(not stuck@24c) and any chance you can send me your bios please?
On another note, what is the Asics like on these cards,the locked voltage cheap XFX DD's have all been mostly high Asics-from reading about forums, I'm hoping for a low Asic(personal preference having used 5 different 79's), was wondering if it's chip lottery on the Asics or if MSI use any particular Asic for the TFIII.
Low ASIC you are saying is better ?
It is the normal bios. I'm a bit busy at the mo in the evenings but if I'm on the PC I'll zip it up for you. Have checked the ASIC but can't remember properly but its between 70-80 from memory.
Just pulled the trigger on one of these TF's, here's hoping it's a good un.
@Drangueos,
If your looking for 10%, you may want to leave your clocks as is and go for vram oc'ing.
Ref 79's are usually very good for vram clocking(1800+ with a little voltage on the vram if needed) and can make a considerable difference in the likes of Sleeping Dogs/BF3/Hitman etc if you can get northwards of 1600MHz, heat may not be an issue in comparison with core clocking.
, you'll be interested in matt's thread then:
