- 14 Oct 2009
- Rotherham. S.Yorks
ive got a bottle of grants vanilla custard arriving today. Cant wait heard great things
ive got a bottle of grants vanilla custard arriving today. Cant wait heard great things![]()
YepI'm a big fan of the totally wicked gold standard liquids. They're very realistic (their real tabs liquid is a nice sweet "freshly opened marlboro packet smell" taste, but their fruity stuff is bang on)
is their stuff usable as normal straight away as it comes? it seems to say concentrate which makes me think it needs diluting?
Oh dude, you're right. I could have sworn they came as premix as well. My bad! Yeah, you'd need to pick up some PG/VG and nicotine to mix it with.
The red label premix liquids are made with the gold standard concentrates, after some investigation I found, so you could try those.
If you want a good premixed tobacco, House of liquid do an awesome tobacco liquid in their El Toro range called El Cigarillos, which has a very leafy tobacco taste that is just excellent.
Everything else I use is DIY mix so I can't really comment on any other stuff. I'm sure the other guys will have some good recommendations though.
Will do. Going to start tomorrow. Got a few normal fags left.
Has anyone tried the refresher bar juice? The guy in the shop was testing it and let the wife try it she said it was really nice.
Ill see how I get on and then start trying different flavours
Can you just mix them up to make other flavours or does that not work?
Just got some of those Tornado dual-coil jobbies. Not getting on with them though.
I filled one with 40 or so drops of El Cigarillos and let it stand, but it vapes with a flavour of burned plastic. Do they take a while to bed in?
i'm confused as to what is the difference between the ego v3 and the ce5 clearomisers??
is one better than the other? they look very similar.
Are you on about the tanks?
I always had issues with them either not wicking well enough (you usually need to give a few dry pulls on it to get things moving) or flooding.
If you're on about the cartos I always harp on about, then you need to fill them with loads of liquid (don't get it down the hole in the middle, drip down the side) until they look moist on top and it doesn't soak away quickly (the first time you do it can take a few minutes because the wick is denser when they're new) or until liquid drips out the bottom (too much!). I once made the mistake of dumping loads in, thinking it was full and then puffing away only to get a burnt taste. It takes a while to soak through so keep topping it up until one of the above happens.
Got my Vision eGo up and running, safe to say i'm pretty impressed with it, great taste, great vape and a satisfying alternative to smoking most importantly the much healthier and cleaner way.
Gonna order a few Cartomizers to keep topped up and currently just on the regular menthol which came with my starter kit which im also curious as to what MG of Nicotine is in it as Ive had a little old school niccy rush baring in mind I smoked Benson Silver 6/10 per day maybe im just getting used to it but may buy a lower dosage once I find out what it is does anyone know? Ive previously posted what kit I bought but here it is again http://www.ecigwizard.com/electronic-cigarette-starter-kits/starter-bundle/standardbundle.html ...
Top 3 Flavours guys? Im interested in trying a fruity one maybe Blueberry?
What maintenance do you guys take after a day/couple of days use cleaning wise?
