Need some new snow foam,what's the best on the market nowadays?
Magifoam is good as is valet pro ph neutral snow foam, they're all about the same, a lot of people prefer a citrus pre wash sprayed on with a pressure sprayer too.
Hi guys,
Is there a better alternative to what I currently use :
Autoglym Bottle Quality Bodywork Shampoo
Autoglym Super Resin Polish
It seems to work nicely but I'm sure there is better stuff out there? I usually just wash with the bodywork shampoo, dry with chamois, and put on the resin polish and buff it off.
Hi guys,
Thanks for the info guys.
Oh dear, no I don't seal it! Was unaware of this, I thought it was a lot of work polishing and buffing to make it look good for a couple of weeks! Huge thanks for enlightening me.
I will take a look at that finnish kare fk1000p, where is the best place to purchase, and any other wax recommendations? Would rather not spend more than 15 if poss!
Cheers, can't believe I wasn't sealing after polish![]()
Excellent stuff, I might give that Serious Performance Ultra 1000P Hi-Temp Sealant a go if it comes with a free applicator.
So basically the process is AG Body Shampoo > Dry with a large drying towel > Apply super resin polish > Buff off > Apply wax/sealant > buff off.
What do you mean? It doesn't leave anything behind, that's the whole point.
Thanks for the links, I can see how it gets pricey quickly!
I think I do need to clay my car as the surface feels gritty in places. Yes I do use the 2 bucket method, but I don't have one of those grit guards. I use a microfibre noodle wash mitt.
How to you "remove" the clay?
