All smokers and vapers MUST watch this video
Good speech, but only 5 people to hear it.
Go mark pawsey! Good to see we gave a friend in parliament
still cant order any more grants vanilla custard, only got 1 bottle left i hope he re opens soon![]()
Just to clarify, the twist has an ego fitting, which also takes 510 fitting atties. The only difference is that ego fit atties have a skirt that fits flush on the battery, and 510 doesn't. Simples. Mini vivi novas are god stuff and can be had cheaply from vapourhut, but I think they're version 1.
I'm going to be buying my next batch of liquids in DIY format. I've asked before but have a few more question on how to do it.
I always buy Liberty flights XO PG 8mg (30ml bottles). I have used their calculator and come up with this.
Nicotine Base Strength [PG/VG] (mg): 54 (PG mix or VG for better vape producer??)
Desired Nicotine Strength (mg): 8mg
Dilution [Distilled Water / Vodka] (%): NONE
Flavouring (%): 12%
Required quantity (ml): 30ml
Drops per std 1ml (no. of drops): 20 (no idea what this is but its set as standard)
ml/Drops/%
PG (or VG for the vape??) with Nicotine:
4.5 90 15
PG zero Nicotine:
21.9 438 73
Water/Alcohol:
0 0 0
Flavouring:
3.6 72 12
The http://www.todmuller.com/ejuice/ejuice.php I buy from LF has decent vape and a mild throat hit, so I think they use VG in there somewhere. Whats the water/alcohol mixer for, just for using VG mixer? I set it to zero since PG wont need it, am I correct?
Could I use those 438 drops of mixer with half VG and half PG?
Any help on this will be appreciated as I don't want to muck this up.
Finally joined the club, my vape thing came through along with the El Toro juices.
Initial thoughts are the cigerellos are a bit too strong for me, a bit too much throat hit, even though I got the weakest one.
Whereas Eden is nice, a little sweet...
So I made a mix maybe 90% Eden, 10% Cigerellos and its perfect for me.
So other GVN are there any other juices you guys would recommend? Unfortunately the GVN site is down![]()
Once I get home from work the CE8 I ordered should have arrived looking forward to trying this out will let you guys know how I go on for those who may be interested.
Could someone suggest me a VV battery something like the eGo Twist VV maybe, nothing too expensive for my first VV device.
And also a seller which stocks this and has in stock UK based.
I don't ask for much huh!
