Man you dont run prime to test 32mb stability. You dont need all those volts either. Use mem test to test Dimm stability looping test 2 and 5. Once thats stable push your overclock up. More volts is often not the answer to 32mb stability.
RAW CPU speed then dimms then BLK.
I think everyone should be limited to one entry on the scoreboard, maybe?![]()
