I just hope the temperature doesn't increase with the weather.
You can guarantee it will
But you can pretty much also guarantee a 30c drop on a direct-to-die block with Liquid Ultra/Pro
You can guarantee it will![]()
But you can pretty much also guarantee a 30c drop on a direct-to-die block with Liquid Ultra/Pro![]()
You can do it!!!
You have to use the force![]()
Delidded with EK-Supremecy & Liquid Pro, have the Naked Ivy on order & will definately do some before & after temp tests when it arrives.
Temps aren't the problem for me atm, getting the PC to boot at the required speed and complete Superpi is![]()
I did try using the force this weekend but failed at:
a) Winning the Euro
b) Winning the Lottery
c) Completing Super pi sub 6m17s
My chip just doesn't want to play ball. The bios on P8Z7-V keeps getting its multiplier settings stuck which doesn't help.![]()
I can;t compete with the new gen stuff, but here's my first go.
8m 49.319
http://valid.canardpc.com/2771117
I'm dead chuffed that I'm even on the same page as you guys! Especially when you consider I'm still running the RAM at stock speeds (well SPD settings), and all the voltages are on auto.
.... and I was browsing t'internet with flagrant disregard for my performance. At least I come top in one thing.... I've got the most Ram in that list![]()
8m 49.319
those chips have good imc's you should try and run your ram at a higher speed although 24gb is a lot,good board aswell
Yeah a section for those of us that are on water would give the Air cooled guys a good chance to fight it out over their top spot![]()
Just cut a side out of the case and use some ventilation tubing and dangle that out the window with a fan to suck in the cold wintery air![]()
You beat my i5 760 by 2 seconds
Think i may have to try again.
Unfortunately he has Corsair Vengeance LP dimms, they're terrible overclockers![]()
