- 30 Nov 2011
Prime 95 will test your CPU and system RAM, not the graphics card
set it to blend to start with and click ok
if you want to get fancy and know how much RAM you have and how many cores / threads your CPU is then you can put it on Custom, set the number of threads equal to your CPU and the memory to use to 90% of the amount of RAM you have
let it run for 15 minutes and if you get no errors on that then it would indicate your CPU and system memory are fine
