7970/50 Arctic Accelero Users
No thanks LtMatt, ive borrowed my friends 6850 so rolling with that till i get sorted. Thank you though.
Doesnt look youll get your spare cooler now....
Ah well it wasn't meant to be mate. Let us know how you get on with those sinks you showed me via trust. ;)
Still waiting on mine.. 4 weeks and still out of stock... I cant wait to get stuck into this project.
Where, from here? Its been out out of stock since xmass. Best bet is the rainforest site. Search for for "DCACOV15G300BL" Its currently £48.30 plus £5 shipping (from Germany but only took 4 days)
I got told a couple of weeks ago they will be in stock in a week. Then a week later when i asked again I got told in a few days. I don't mind waiting a month or so as id rather buy from OCUK. But if it not back in stock after soon. Ill probably try and go else where.
Hmm not gone well. Everything is in as instructed. When i turn PC on it turns on for half a second and just cuts out, any ideas? I tried booting without card in and boots fine
Like these?
Also Gelly make sure that no heatsink is touching the main baseplate of the cooler. Its possible the bottom vram one might touch the main heatsink if not positioned incorrectly.
Hate to say it thats what happened to mine as you know the larger l shape sinks are to tight a fit, i did the same thing using the insulation tape and larger sinks to but when trying to start the card would only spin up for a split second and when the card was removed the pc would run fine then on the second attempt the card gave out a puff of smoke' luckily i was able to rma i then just followed the accelero guide using permanent adhesive on the vrm's which are a beter fit.
Yeah same problem as you. Damn it! (although no cloud of smoke) should have just followed the instructions with it. RMA it is then. LtMatt could you send me them pads please?
