Bloody hell, was it parked in the sea?!![]()
They don't call it Mariner blue for any old reason you know
They don't call it Mariner blue for any old reason you know![]()
The suage line looks distorted in the first pic. What happened there?
Is that a racing beat exhaust too? Had one on mine, sounded lovely.
Good effort with the 5, Where did you get it done ? Looks mint.
Are you on Nutz or Phoenix 5's ? You need to bring that to one of our meets.![]()
Well the meets are getting busy & frequent so get yourself back on there.![]()
Worked out that the rattling noise is coming from my front brake pads, as they don't sit as snugly in the carriers as they ought to. Trouble is I'm torn between trying more grease and stick-on shims to quieten them down, or just ordering some Ford OEM ones that will no doubt fit better for the sake of £40. But doing this seems like a bit of a waste seeing as there's plenty of meat on the Pagid pads.
I'm also not sure if the mk3 Mondeo should have pad retaining / anti-rattle springs or not (like what you can just about see in the photo above, incidentally).
