- 24 Sep 2005
- Middlesbrough
Can I bring a friend? He's rubbish but he won't get in peoples way, there's no chance he will win![]()
I'm going already.
Yeah no problem, we still have a few spots free.
I will put you down as +1.
Well I may or may not be able to make this. As per usual with the GT6 a simple job (changing the front pads) is not quite as simple as it should have been.
The plan was to get it all sorted over last weekend but the bleed valve on the calipers had seized and wouldn't unscrew. It has taken 2 days of applying gas oil to release them and I won't have time now to fit the new pads till Saturday morning. So I may arrive or I may not, it all depends if the car throws another spanner in the works![]()
Does large amounts of gaffa tape keeping the GoPro on the helmet count as "well secured"?
As I have both a GoPro and a Contour helmet cam, I think I shall try the GoPro as a rearward facing camera... Should capture most of you!![]()
Anyone going from Woking area for the karting and the pub afterwards? Howard, I'm looking at you here! The Elise is still in MANY pieces and it doesn't seem worth bringing the Bora so I'm willing to go halves on petrol for a nicer ride![]()
