You can buy a meter that plugs into the plug socket and measures how much you are using. Although actually that is not telling you the max output of the psu.
Antec ones are usually good... I think a lot of the branded ones are probably made by OEM such as Antec, seasonic etc. anyway. Not sure who makes the coolermaster ones.
Not sure about Enhance electronics, never heard of them... Personally I would get Seasonic, antec or Corsair and avoid XFX and OCZ. Best to look at a review because they all seem to vary, for example one brand might use different OEM for different models in the same range etc. Its quite confusing
 I edited my post.
 I edited my post.Although if you leave the PSU until it "goes poof" it might take out your motherboard or other components with it as well. Probably not with a good brand like Corsair though.
tells you how much you are using - but not how much headroom you have ....
my 570 as said above I get to about 450W under absolute full load
with my 480 I was getting to 550W ... actual draw from the mains
Just seen a screen grab from some european stores list pricing....887 euros
I really really hope its BS. Actually looking forward to the 23rd, Nvidia should take note that I have some money burning a hole in my pocket but I'm not going to spend it on something that isn't worth it.
