There are a fair few games that will make a pair of 670s squirm. Tomb raider maxed, Crysis 3 maxed, Hitman Absolution maxed to name but a few.
They all run ok for me at 1440p but everyones opinion of ok is different.
They don't run OK on true maximum settings. Not even close. You'd be looking at single digit FPS in Tomb Raider alone. Hitman would be OK but Crysis 3 not happening either.
But if you turn off that silly hair thing then it is probably fine.
Is there anyone here who has said they will be getting a GTX 780 or 770
Yes, I will definitely be getting one or the other - it's all price dependent now. And if the 770 is priced at a very fair point then I will consider SLI 770s. But, either way, I shall be getting one or two 770s or one 780 - simply due to the fact that I don't actually have a desktop at the moment and so I'm starting fresh with a new build.
I expect a number of people may be getting a 780 depending on price given it is really what the 680 was supposed to be.
3D Vision kills my 670s in most of the new games. I've got until the 28th until my evga step up runs out so will consider a move to 780s if the price to do so isn't horrendous.
It all depends on the game, Metro with advanced Physx runs pretty much locked to 60Fps on 670 SLI @ 1440p. I would say Metro looks better than either Crysis or Tomb raider at max settings with the Advanced Physx adding a fair bit.
But that isn't what you initially said. You said any game but I've provided examples of games which don't run that well maxed out at 2560*1440. I'm not advocating getting Titans or anything to run high levels of AA as the benefits are relatively small at that resolution but more just pointing that there are games which 670s (and 7970s/680s) can't max out at that resolution.
I was just pointing out that there are games that look better with more physics effects than the games you mentioned that run fine. It's very game specific. But yes upping the AA to high levels kills FPS. The games you mentioned to me run fine but I'm not using lots of AA as at 1440p it's not really worth it.
I think my idea of max is different to yours....To me enabling features that kill FPS but make no viewable difference is not running max it's benchmarking.
Movie style textures would be very demanding on any setup.
