- 12 Feb 2009
- UK
How would I use this? Do they remove any VAT before I pay or refund it after?
Well I thought the kids coming through now got a CCNA certificate with the opportunity to so 3 other CCNA courses if their role requires it.
They definitely pay Cisco a lot of money if its not a proper qualification![]()
I'm pretty sure you can still do CCNA 1 - 4 at flowerdown? Or do they not give you the the full CCNA qualification?
Ah so pretty much like a JPA record saying you've completed the 'CCNA' course? Completely untransferable to civvy street, except for any experience you get.
Though I think you can do all 4 semesters at flowerdown, I don't think the RAF put you through the final exam though.
Is it just a case of buying a different ended kettle lead to use my monitor and PC in germany?
Does anyone have any comments/ advice for someone considering joining the RAF after a degree as an intelligence/ other support role officer?
).IntO is difficult to enter, I'm unsure if they are even recruiting that role at the moment. If it were to be open I'd put their recruitment target in the single figures, meaning out of hundreds of applicants every year you need to be in the top few %. Once in you will then be struggling for promotion as the branch is extremely competitive. Look forward to years of scrambling over one another to get that elusive recommendation for promotion which probably won't come anyway after the board sits. The junior officers (flight lieutenant and below) get run ragged too. When you're fed up with all that you then find you don't have many transferable skills into civvy street when you want to bang out.
If I were applying I'd probably look at Supply Officer. As dull as it might sound, it isn't. Promotion is much quicker (assuming you're good enough) and the skills are very transferable, particularly if you gain qualifications in POL (Petrols Oils & Lubricants).
Back to the exact same tiny place in the Falklands in July after only returning last February. Deep joy.
I'm off to Minhad in July, going to be a different temperature extreme.
Apparetly I'm a "Class 3 heat risk" according to the PTI's. As I'll be working outside with no Air Conditioning.
They want me to run around the gym for 7 weeks to acclimatise, sounds like a lot of ******** to me.
You'll like it, it's like a holiday. Look out for two blonde female movers out there. Not bad looking, thick as **** though![]()
