Was mad?
Well.
Tested bottom dvi - no luck
Tested top dvi - catleap 1440p monitor works fine
Tested hdmi - no luck
Tested mini dp 1 - works with apple adapter on hazro
Tested mini dp 2 - works but produces fuzzy lines
Put never winter on and it ran ok.
Card buzzes when idle... no idea why but under load if silent.
Will keep useing it for a day or so and if its still ok I will watercool it.
Bargin ;)
Well.
Bargin ;)
Seems you got a bargain :cool:
It crashed after 15 mins in Bf3, So i have disabled ULPS
Its flickering idle due to downclocking to 300/150, anyone remember how to keep that up? i forgot lol
There are two plugged in all ready :/
1 via DVI-D and 1 via Displayport
Strange, and you have them both turned on right ? and if you do and its down clocking to 300/150 ect then that should not be happening, as thats the reason why your screen is flickering, they should be running @ 500/1375 and not dropping, i am running 2 cards and 1 plasma and 1 monitor and 1 of my cards runs at 500/1375 all the time and 1 runs at 300/150. which is normal..
but yours seems to be down clocking even though you have more than 1 connected display. strange indeed, probably a fault with driver configuration, or drivers need reinstalled.
Updated the OP.
I also found that without the Red button pressed in the DVI ports don't work at all. Only one MiniDp would :/
With it pressed in though i get the use of the DVI-D back.
Oh and to make things better, i have control of the Vcore and Vmem settings! This card has some hefty VRM's so i will have some fun overclocking this beast!
I fixed the Flickering by reinstalling 13.4 Drivers :)
Isn't the red button just a BIOS selector? with only the one selected in the "in" position supporting over clocking, could be the BIOS selected in the "out" position is just corrupt /shrug
