On way to apple in leicester highcross to get a new Mini DP to Dual link DVI adapter today, They will price match![]()
O.O
Well.
Tested bottom dvi - no luck
Tested top dvi - catleap 1440p monitor works fine
Tested hdmi - no luck
Tested mini dp 1 - works with apple adapter on hazro
Tested mini dp 2 - works but produces fuzzy lines
Put never winter on and it ran ok.
Card buzzes when idle... no idea why but under load if silent.
Will keep useing it for a day or so and if its still ok I will watercool it.
Bargin![]()
Seems like listening to your balls is a good thing
When you've sold your 7970 it's probably cost you £150-£200 for the upgrade? (inc WB)
It crashed after 15 mins in Bf3, So i have disabled ULPS
Its flickering idle due to downclocking to 300/150, anyone remember how to keep that up? i forgot lol
To keep it up plug in another monitor so the clocks stay at 500/300
There are two plugged in all ready :/
1 via DVI-D and 1 via Displayport
Wow your brave but it looks like it payed off, you gonna have a go at overclocking it?![]()
