Im getting recollections of you and illuz's little battle in his other 32m thread.![]()
yh I better watchout once hes come off the naughty step
Just thought I would have a go at beating 8pack just to see if I could. 4.018Ghz on cpu and NB, 2813mhz 9-11-9-25-121-1T and I hit 7m39.911s
Needs tweaking but I am sure I could shave a few seconds off... Not going to beat 8pack with that though.. a 40x100.45 needs to be replaced with a 39 x 102.7ish but the memory doesnt like running faster than 2820cl9 so its a no go from me.
Interesting comp though![]()
What memory kits are you using to get CL9 at 2800Mhz?
And what volts are you using on the ram ?
Since I am not entering I weill share the tips I used to use for getting the fastest superpi 32m times. This worked on x58 cpus and I don't think anything much has changed since so the theory should still be fine.
Tip 1. Run windows xp pro with sp3 or server 2003, not windows 7 or 8. Ideally lite or stripped verions (lite/stripped versions save about 7 secs from a 9min time)
Tip 2 Disable sound, lan and anything else you dont need in the bios
Tip 3 Run msconfig and disable all services not needed
Tip 4 Set colour schem to olive green and remove background
Tip 5 Turn HT OFF
Tip 6 Go to system properties, click on the Advanved Tab then advanced tab again. Set Processor scheduling to Background services. Set memory usage to System cache. Now under virtual memory click change. Create a custom size of Initial size 512 and a max of 512 on your c drive.
Tip 7 Open regedit. Navigate to [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\SessionManager\Memory Management]. Select Large System Cache and make sure the volume is set to 1.
Tip 8 Run msconfig again. Go to boot.ini tab and click on advanced. Set maxmem to 600 and make sure pcilock is ticked.
Already all of the above should save you 20 to 25 secs from a 9 min time......
More tips to come soon........
Couldnt have helped much more if you tried eh! My issue is that i am on windows 8, sub that out for tiny xp and I am looking at about 7m30s or so.. itll then just be tweaking thatll find me those extra few seconds although a few of those tips only produce minute differences on todays hardware that may not even reflect on a run.
1.68v![]()
