AMD FX-9000 - FX-8770 CPU's.
Edit ^^^^ yeah...
It seems rather strange AMD would send their review parts from Finland,when they have no offices in that country!
That would explain it then as he works for AMD.
Is it a test sample? its possible that its doing its rounds to reviewers.
IMG_3491_zpsdd1fef61.jpg~original
Its chip spanking time!!!
Stulid any chance any of them are the new Fx-9000? I'd love to know if it overclocks at all. I have the Fx-8350 at 4.8ghz and can bench at 5ghz but not comfortable running 1.5v through it for every day usage.
That's only because for 5ghz you need to pump 1.5V or something ridiculous through it, for reference a 4.6ghz 2700K on a sensible voltage uses about 130W and a 3930K at 4.6ghz uses about 190W (both under Prime95).
I bet these CPU's can't even run Prime95 without throttling.
My 3930K draws over 500W when overclocked, mileages vary due to volts.
From memory mine slurps on around 520W at 4.7GHZ @ 1.45-1.48V
Skies the limit at 5GHZ @ 1.56V
It will only draw under 190W at default volts and clocks.
TDP isn't power draw.
And this CPU isn't 5GHZ!
A 2600K at 5GHZ (Proper 5GHZ, under all load) going 100% would have a pretty high TDP/Power draw.
