The problems of CF are massively overstated but it's undeniable that they exist for some. It's probably a bit of user problems chucked in as well as genuine issues. Fishing out the actual genuine issue is a minefield. One which I'm staying well away from from.![]()
As rusty has said the brand new 770 is trading blows with the year + old 7950 (sorry meant 7970) at the same price point. Great...
Really is this the best nvidia can do at this price? No wonder AMD aren't in a hurry to produce the 8*** series.
Got a bit excited yesterday, the 770's and were all listed for under £300 on OcUK for a while, they went back up after that![]()
What? From those charts above it is clear that a overlcocked 770 and an overclocked 7970 are very evenly matched.
Benchmarks at 1920x1080 since its most common resolution aside, any real gamer on the PC machine runs at least 1440p or bigger resolutions.
anyhow this below is one result. Personally I dont buy overpriced hardware that only give you bragging rights or such as for me unless the difference is actual in my use in practice and mesureable as I game, why buy something new that dont allow you a better experience?
I dont buy a new ssd for example as my current crucial M4 128gb is fine for my use and the funny thing I wont notice any difference if I bought a new one. Tech is slowing down big time.
I bought a 7970 due to the 680 too expensive and also not fast enough at my resolution and I waited 6 months until the 7970 was had for the same price it is at current pricepoint a superb deal.
No sane person buys Nvidia.
The below conclusion: Quote" The HD 7970 still clearly beats or matches the GTX 770 in all of the benchmarks except for Civ 5 and HWBot Heaven Xtreme. So, my personal opinion of the GTX 770 doesn’t change in light of the new results. The GTX 770 costs the same, but performs worse than the HD 7970 on average. If one needs some of NVIDIA’s exclusive features in the $400 price range, then the GTX 770 is the card to get. Otherwise, a little more performance can be had from the HD 7970." end quote.
http://www.overclockers.com/hd7970-gaming-benchmark-results-update
I decided to run Hitman out of curiosity sake. In 1080P, neither GPU went above 60% usage and the CPU was at 4.7Ghz.
I then ran it at 5960x1080 and both GPU's were at 99%
Surprising how little the GPU's were used at 1920x1080 but nice to see them running at full speed at the bigger resolution. A very good looking game but I do find it a tad boring.
Ran a comparison for you at 1080p, Ultra x8AA. Gpu usage was around 87-90% with my cpu at 4.7ghz.
I am scratching my head a little as to why the GPU usage was so low on my run.
I'm a little confused by the benchmarking results for Farcry3/Tomb raider as i get at least 5/10FPS on avg more out of the box.
