That's look like main road as that's what BT Engineer told me they only do it on the roadside.
ah I understand now
Hmm ok thanks, I will give the ISP a call and try and find out the options.
Just on the off chance, this isn't already a master socket is it? it looks 'busier' that I expected, guess the previous owner could have already moved it.
That's just a standard socket.
That's an old style LJU master socket (the ring capacitor is an obvious giveaway) not a "standard socket"
Cool thanks, so is that suitable for the fiber install as-is? As long as it's some kind of 'master' I assume it just needs brining into the correct century?
Did they contact you, or you them?
If you know where your cabinet is, and read this page you should get an idea of realistically what you can expect.
OpenReach estimates are fairly conservative towards the higher end of the speed scale, and more accurate towards the lower end.For example, the ADSL checker says I'm estimated for 59.1Mb/s down, and 20Mb/s up. I'm 320M from my cabinet (by road), so I'll probably get ~75Mb/s.
. I make it just a shade under 500M (probably 480M), so yeah 51.5Mbps/13.2Mbps is probably a bit conservative.Well that happened as planned, a shiny new FTTC cabinet was fitted.Roadworks.org said:Works Start: 03 May
End: 17 May
Medium impact, delays possible
Description : Install 3m of 1 way poly duct in Footway,Provide 1 Provide/Recover 1 NGA Cab and base (1.5m x 0.5m)
Current status: Advanced planning
Traffic lights, etc: None/signing only
And then that happened, they dug up the road again by the new cabinet, fiddled with the power cable, and tarmaced it over again.Roadworks.org said:Works Start: 19 Jun
End: 21 Jun
Description : Install 4m of 1 way power duct in Footway,Performing an 1excavation to expose existing power cable in Footway
. Soo... what's next?Soo... what's next?
Today my exchange has changed from a "future exchange" with a date of "end 2013" to "Coming Soon" and September 2013.
Getting excited - progress at last I think![]()
.Does anyone know any way to complain to BT Openreach? Or even just speak to them? They dont seem to have any customer facing front end, but Plusnet can't really do anything other than chase them about the no show from an engineer today. I'm now without BB or phone for likely a couple of weeks while I arrange another booking and take another day off work, while Openreach seem to have just got away with it and are completely unaccountable as you can't contact them.
(which he wasn't too happy about but was understanding and did a pretty decent job of sorting what actually turned out to be a fairly big botch by the previous guy). Crazy that theres nothing in place for a level of service between those 2 extremes.
