- 14 Oct 2009
- Rotherham. S.Yorks
i have emailed him, hopefully i can bypass the website and get some sorted, hes a good sport old grant
Actually, that was going to be my next question.
Can you store these tanks filled and ready to vape or are there issues with leaking, etc? I'd like to have a selection of flavours on the go and swap between them as I see fit.
Perhaps I'm not reading things correctly, but that juice appears to only available in varying strengths of nicotine? Or is there a 'pure' version as well?
Lovely stuff, that'll give me some reading matter!
Thanks!
Just got my Protank and am very impressed. Much better than the CE5's I have been using. Think I will need a new battery next as it just looks odd with an Ego.
you can get a case of 'shinyitus'
Just a heads up, Grants site is open and taking orders again. Gogogogogo!
Been dying to taste this stuff after seeing the reviews for it.Tried re-wicking my Protanks and Evod clearomisers for the first time last night. Surprisingly my first three attempts all worked!! Much easier than I thought it would be.
Maximum resistance I've managed to get so far is 1.9 ohm but I usually vape on 2.5 ohm heads. But I can't seem to get it beyond 1.9. I'm using 2mm ekowool and have tried both 0.2 and 0.3 mm wire. The maximum number of coils I can manage without shorting the head is 5 turns, anything more than that and the coil always touches the metal head.
Anyone here rewick at 2.5 ohm? What setup do you use?
Why would you want such a high resistance?
Try using 0.15 wire, you should easily get it to 2.5 ohms with 3, max 4 turns.
Cheers. So is it thinner wire for higher resistance then?
This is why i said I think ego users should go with the Evod, or the Protank Mini!
http://www.sz-kanger.com/collection...izer/products/kanger-mini-protank-clearomizer
I got a package a few days ago that i ordered about a month ago from Fasttech.... I'd forgotten i'd ordered it. I did have a few drinks that evening....
A Vamo V3! Its not bad, not sure i like the spiral design. Like the removeable ring on top, much easier to clean now. The new screens nice, no more N01/N02 mode, slightly different menu system. Other than that its much the same.
Will post pics later if i'm at home.
