- 10 Mar 2006
repost
Didn't expect that much grunt! Just by holding it upright and pushing the throttle up it can easily hold itself in the air from about half throttle. Wondering how it'll be balanced though with a 2200mah battery up front as I can't see any Centre of Gravity markers on the wings.
The battery has been made to fit by heating up a screwdriver with a creme-brulee blow torch (classy) and then just cutting out the foam when it's red hot. Came out nicely. The fumes that come off that foam though... had a lungful by mistake, not good.
Happy to get out the duct tape / fibreglass to keep it going, if I'm any good I'll invest in something better at a later date. Could someone spec me a complete kit to join the club? I've already got a dx6i transmitter that Iuse with heli's.
Something cheap, I. E. If I crash it I don't want to get too upsetHappy to get out the duct tape / fibreglass to keep it going, if I'm any good I'll invest in something better at a later date.
Is it possible to launch from a field or by hand rather than having to find a RC plane runway?
Have a look at the turniqy 9xr, probably the best value tx out there. The software on them is a bid fiddly, but they come with a connector that you can use to upgrade the software.Can anyone give me some advice regarding Transmitters?
At present I'm still using an old 35MHz Futaba FF6 TX and am looking for an upgrade.
I'm thinking about getting either a Futaba 6J or 8J Tx and would like to know if anyone has any experience of using either one?
However for around the price of the 8J I could get a 7C Tx which uses FASST, would it be better to go for this or get the extra features of the 8J?
At present I fly just IC aircraft, but I may look at getting a quadcopter (or similar) at some point in the future. I would also like to stick with Futaba unless another manufacture offer a much better system for around the same price.
http://www.hobbyking.com/hobbyking/store/__25003__Bixler_v1_1_EPO_1400mm_ARF_UK_Warehouse_.html
http://www.hobbyking.com/hobbyking/store/__26032__Hobbyking_SS_Series_25_30A_ESC_UK_Warehouse_.html
http://www.hobbyking.com/hobbyking/...y_2200mAh_3S_20C_Lipo_Pack_UK_Warehouse_.html
http://www.hobbyking.com/hobbyking/..._Compatible_7Ch_w_Failsafe_UK_Warehouse_.html
Only other thing you would need is some connectors to solder onto the ESC. Great 1st plane.
Absolutely fab, that looks perfect.
Would these be the right connectors?
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9572
Ended up going for the bixler 2 as there was no stock for v1.
The order is currently held up by customs so looks like I'll be getting stung, an online calc suggest £16 so not too bad.
Does anyone use Pheonix flight sim? I'm looking for suggestions of which plane might be similar characteristics to the bixler 2 so I can get some practise in![]()
