Bought quite a few bits to sort out some interior issues on my car this week.
1) Wanted a replacement gear knob top, but they wouldn't sell me it, so I've had to buy a whole new assembly.
2) New steering wheel controls, the volume is broken where I hit it in anger once.
3) New indicator stick with cruise control, CC has never worked but one of the CC controls is broken, so first step is making sure they all work then carry on investigating from there.
4) New Climate control unit for the interior, fan speed buttons were broken by the previous owner, so I'm replacing it.
5) New antenna, originally from Saab they are made from rubber and in the heat it perished and cracked, got out of the car the other day and noticed it was gone with just the antenna sticking out
- So have bought a plastic one thats painted the right colour so should look better than the original
6) Parking sensor kit - £15 from the bay, and in the right colour...be rude not to.
Also aside from that, looking through the receipts a previous owner had an Aux-in kit at some point and its enabled in the audio menus, but he must've taken it with him...bummer, plus side is that if I refit an aux kit I don't need to take it to Saab to get it activated...so found a guide online and have started purchasing the bits to make my own. It will cost me roughly £9 to buy all the parts and about an hours worth of swearing to fit it.
Better than paying £55 for what is effectively a cable from Saab anyway!
So lots happening this weekend with fitting that lot! Also hopefully going to repair the outside temp sensor that the dingbats at Fords broke when it was being repaired from an accident at the start of the year. Hoping its a loose cable or similar.
