- 29 Aug 2010
- Cornwall
Its free enough to be able to run the stress test.
To clarify, do you mean use the 30 day Trial or are you saying the stress test part is free?
I had a little test. Upped the multiplier to 45, put vcore on 1.285v and LLC to high, no problems booting and running stuff but I've done no stress testing. On the Gene I'm sure this wouldn't boot.
More GIGABYTE Z87X-OC X01 bios profiles with GSkill Pi2200C7, Trident 2000C9 and Patriot PSC for air and subzero CAS6 and 7
Dinos22
p.s. generic testing notes are in the rar file also
With Haswell, does RAM speed have any effect on OC ability?
I thought that link said that the more you OC the CPU the worse the IMC performs? If that's true then does it also follow that you can get a better OC with lower RAM speeds/timings?
watch this video
Turbo = 4.2ghz OC apparently.
Ok i have tried this turbo button and in the bios the vcore went to 1.4X that sounds really bad ?.
Thought I'd see if I could do 4.1GHz at 1.26v, but it's not stable. Do I have a contender for the worst 4670K ever?
Do you guys all have 4770Ks? Do they generally clock better? I'd have though heat would've been a bigger problem with the HT?
Tempted to sell my 4670K (if anyone would buy it) and get a 4770K.
4.6-4.8GHz is easy to do.
My first 4770K needed about 1.30v to reach 3.9GHz, so I returned that one. I haven't had time to test the replacement properly, but I'm running at 4.5GHz at 1.285v stable on the OC board (I've done zero stress testing, and have only been doing standard desktop stuff so far).
