Little bump on the 780... that's about it without using any extra voltage, which it could do with on the bloody memory first
Intel 3570K @4.4ghz
GTX 780 @ 1072/ 1577
And updated.
Intel 3570K @4.4ghz
Here is mine
Sapphire AMD 7990 water cooled and clocked to
GPU 1225
MEM 1725
Volts 1.3
CPU 3930k water cooled and 4.8Ghz with 1866 RAM
Is there any chance of the in bench screen shot so I can put it on the scoreboard.
Thanks
Here we go, managed to up the mem as well
CPU 3930k @ 4.8
GPU 1225 / 1750
All Water Cooled
It is a good score too
And on the scoreboard.![]()
Very good cards I'm impressed, I think I could add a good bit to that score If Leant on it but very happy with those numbers.
Asus GTX780 Direct CU11 @ 1059/1777 and Intel 3570K @4.2ghz
I don't know if I earn a second slot as it's a different 780 and has Samsung memoryVery good cards I'm impressed, I think I could add a good bit to that score If Leant on it but very happy with those numbers.
Sorry you only get one score per card type, if you ran the same card with a different CPU then you would get another slot.
Nice score though
Scoreboard updated.![]()
You rotter...thought it was a GFX card test
I am very pleased with that,![]()
Can you imagine the nightmare it would be for me updating all my GPUs individually.
And yes it is a good score, above a number of Titans.![]()
, 780's are a very good distance behind a Titan, the table misleads just because the 780's can be overclocked much easier, If everyone posted clocks in the same way I think that would be very apparent.MSI GeForce GTX 680 Power Edition/Lightning
GPU 1280
MEM 1902
Volts 1.315
CPU 2500k and 4.4Ghz with 2133 RAM
Get those GPU's clocked and that CPU![]()
