- 29 Aug 2010
- Cornwall
For the water cooling side, yes some of the stuff I bought before hand thinking it would fit did not, so had to change plans, would be nice to have an Obsidian version of this case, all aluminium with a couple of extra inches length and hight.
As for air cooling, not sure what you could possibly have trouble with such, seems ideal for air cooling.
I can't agree with this.
Any water cooled build will be challenging and with the 540 most of us are putting more than a single radiator in which will always make it harder.
I will accept that positioning a pump and res is not as easy as it should be and the lack of ability to use a bay Res is a serious flaw.
As for Air cooling... well what's awkward there... its very, very easy.
Cant agree with GoogalyMoogaly. Transferred everything into the 540 and it was extremely easy. Couldnt have gone better tbh.
I'm not saying that air cooling was hard, but I can't say it was that much easier than my HAF 932 or my TJ11. Probably was easier than my CM 690 II.
Water cooling, my big problem was mounting the pump/res, filling the pump/res (maybe shoulda done that the other way around) and getting the tubes into the 'business' side of the case.
In my opinion in my HAF 932 mounting the pump was easier (used a bay-res, I'll admit that was noisier), filling it was much easier and there wasn't any difficulty in the slightest and no requirement for angled fittings or anything like that to get the tubes from the pump to the CPU, to the rad and back to the pump.
The air cooling things I disliked/found awkward were:
- I dislike the way you have to remove 2 thumbscrews and 2 'panels' to be able to clean the front dust filter.
- I dislike that the optical drive bays actually prevent you from using the top grommets for any sizable cables (fan cables etc. seem fine).
- I don't think it's particularly easy to cable manage the back compartment. Sure it's easy to throw all the cables in there, but in this case it's a section of the case rather than just being a gap behind the motherboard tray. Keeping the motherboard side neat and the other side messy seems like doing half a job and making excuses.
- I think the SSD assembly could be improved. Just pushing and pulling them apart seems like it could lead to things breaking or becoming loose after repeated use.
- The optical drives seem the wrong way up to me, I'd have rotated them 180º (not sure why though).
- I feel it could've been a little bigger in each dimension.
- Getting positive air pressure seems awkward. Taking the front as intake and top/rear as exhaust (due to no dust filters) you can have 3x120mm (or 2x140mm) intake and 3x140mm exhaust.
- Not enough front-panel USB connectors
- Front-panel USB3 connector could be longer!
With the exception of the cable management stuff I don't think many of them apply to the HAF 932 or TJ11. Just my opinions of course and since people were sharing opinions I thought I'd share mine. It seems to be the thread for discussing the 540 AIR.
With regards to the stock fans, I didn't find them noisey at all, running at around 800rpm. I am thinking of swapping the 2 x 140mms out for 3 x 120mm AF120 fans, but only in an attempt to add more intake air flow.
