- Moving the saddle forward isn't an option as it causes knee pain.
- Stem is 90mm so I don't fancy making it 80mm as it'll probably be too twitchy.
- Not replacing the frame!
You cant change the reach without changing one of these things.
Lifting the bars higher will reduce the reach slightly, but not really a noticeable difference. You could try angling the bars up a little but that's not going to make a huge difference either.
