Unigine Heaven 4 benchmark
Score: 1586
Min FPS: 27.2
Max FPS: 132.5
Mode: 1920 x 1080 8 x AA Fullscreen
Preset: Custom
Quality: Ultra
Tessellation: Extreme
EVGA GTX 780 Superclocked - GPU: 1202 - Mem: 1702
GPU-Z Validation - http://www.techpowerup.com/gpuz/mwkgk/
Core i7 4770K @ 4.60GHZ
Score: 837
Min FPS: 19.8
Max FPS: 75.3
Preset: Custom
Quality: Ultra
780m GTX Overclocked to - GPU: 900 - Mem: 1520 (0.900v)
GPU-Z Validation - http://www.techpowerup.com/gpuz/728bh/
4700MQ Stock at 3.3GHz
Please keep images to below 1280px wide or post in
tags like I've done for you above - Rilot
Still tweaking this and waiting for a custom BIOS before I can overclock the CPU
My new Asus GTX670 from Paul aka pgi947
GPU-1175
Memory-1502
volts 1.21
Rest in my sig.
Hey kaap is this a good score for a 670?
I know im not Kaap but.... :D
Seem a decent score, you could get better if you OC the mem clocks though. I can get 1750 (7Ghz) on mine, that boosted my score a fairly big amount.
I got 931 (i think) for Reference at 1162/1752. :D
Thanks doom:)
This is the higher clocked bios. From looking at the scores yeah it's a very good score:D
Edit: I just looked 2 posts up and I beat a 780 at stock:eek: Am I looking at that right??? If I did then sweet:D
GPU-1175
Memory-1502
volts 1.21
Rest in my sig.
Yes it is a good score and I also agree with Doomedspeed about overclocking the memory.:)
All scores updated.:)
Entry from Gregster
CPU was at 5Ghz and GPU was 1277Mhz/1818Mhz
Best SB-E score.:)
Score updated.:)
Updated score with a oc i tried today. I just bumped the core +85 to make my core default 1000 from 915mhz and it boosted to 1228.1mhz. Was running on 314.22 drivers still which i know arnt the best for this benchmark but still. My cpu remains a i5 3570k at 4ghz.
It completed the run so presume thats good enough. But i will point out at the end i did gpuz render test and trying to move the render box about i had delays of it moving for a sec or two after i released the mouse. Was fine after i clicked on default on precision x to revert to normal speeds. So i duno, make that of what you will.
Edit - forgot the gpuz piccy.
Skeeter could you check to see if you have your integrated graphics turned on please. The screenshot is showing HD4000.
Thanks
