That......case....is....huge.
Love the green fans aswell
Keep them coming!
Thanks Jonny!
I have those fans in my case they look awesome, even more so when I see them in that pic...
HA thanks Colin. They are EOL. It took me ages to find one missing one I needed. Finally found a used one on a German auction website O.0
With all the green I keep thinking "HULK FOLD!!!!!"
Hahaha indeed. HULK MAD, HULK FOLD xD
Most of us who fold using the heavy iron have followed the following guide at the HardOCP forum:
Ubuntu Desktop Installation Guide for F@H
However they have a new concept with the "appliance" route.
[H] Ubuntu Folding Appliance -- alternative approach to Linux folding
As you will have noticed from the description to get the most out of these beasts you need to be using Linux and running on the CPU's only. Then you can get upwards of 7-800K PPD on and AMD rig and near 1 million PPD on an equivalent Extra Spicey Intel quad cpu setup.
Compare that to a quad Titan rig which gets around 4-500K PPD on windows but with a lot higher power consumption.
Running gpu's on them at the same time is currently a no-no other than as an artistic experiment, because it the bigadv work units these rigs crunch are very sensitive to time, any delay can drop the PPD down more than adding the GPU's would make up for, at best you may get equivalence or slightly above but you are then using about double the power to get the same amount of output.
After reading that Biffa I feel like I'm only just dipping my toes into a very big pond ! All sounds rather daunting after having read up on the subject for the last couple weeks.
It can be a bit daunting at first, but it doesn't have to be, the software is a lot more user friendly nowdays and there is a huge amount of community support,
here, at other forums like
[H] and at the offical
Folding@Home forums
Thanks A LOT for the information you have shared Biffa.
For everyone who is interested in this; this forum has an active folding team and they can help you wit hall of your folding questions and problems.
Alright. Finally have some time to post the progress of the past few days.
I have been really busy, even though it might not look like that in the photos
So I took out two pieces of rosters from a case. The rear grill had quite different shapes to it. Plus I took out part of the PSU front grill. I needed to make some room for the sleeving before I paint the inside of the case black.
As you can see I painted some internal loose parts to begin with.
I created a top plexi piece. It will create a much more clean looking top and will also give me some options regarding graphics.
Ordered two pieces of square long 12mm aluminum to later on fit all the acrylic together and make it sturdy for transport.
I then created a few openings in the PSU plexi front so I can put wiring through it with sleeving eventually. I will need to create a few horizontal openings above it for hot air leaving the PSUs. I will need to make those before I paint the plexi black.
After this I created a small roster for under the plexi PSU cover so it will stay level and sturdy also when I fit more stuff to it like the reservoir mounting and the coolant inside of it.
I then created a second plexi piece for under the backside panel. It actually has a function but I will talk about that later.
After this I bent a corner in the top left of the covering rear panel. Actually I FOLDED the corner (CWUTIDIDTHAR
This way it will show a piece of what is under there (the second piece of acrylic).
After this did a final mockup seeing if everything fits.
Here are the photos of the work of today.
