Bugger. I'm forced to agree.
That's the thing you see, people don't like it if you make a point that the limit might be exceeded.
pcper said:Frame times in general are pretty good at 4K resolutions with the 2GB GTX 680 the lone outlier with some noticeable and significant spikes and jumps in performance. The fact that the 4GB variant does not exhibit that problem tells us that the 2GB frame buffer is just not enough to keep up 3840x2160 at these settings.
Both the Titan and the HD 7970 have the best / lowest frame time variance with the GTX 680 2GB coming in last. It is interesting to see the added frame buffer of the 4GB GTX 680 making a noticeable difference in potential stutter.
The GTX Titans in SLI have a very narrow and smooth band of frame times. The GTX 680 4GB frame times are also noticeably tighter and doesn't exhibit nearly as many spikes in frame times as the 2GB models do.
http://www.pcper.com/reviews/Graphi...marked-4K-Resolutions/Battlefield-3-Single-GP
An example of the potential problem 2gb users could face.
