Haha! that made me laugh.. Atleast we have a nice framework to work off now..
So you want "the Big Green machine" to be the "Non-so big Blue and Black Machine"?
Ill get on it.![]()
It can be big, just dont like that case
Ill get on it.![]()
It can be big, just dont like that case![]()
CAUTION: Users may experience extreme motion sickness and/or complete disorientation from the extreme speeds typically reached with HyperX® Predator. It is not intended for small children, the faint-at-heart, people with a lot of time to complete a creative project or anyone who settles for less. Featuring frequencies up to 2666MHz and a new heat spreader for greater heat dissipation, it’s Intel XMP ready, compatible with all popular brands of motherboards and backed by legendary Kingston® reliability. We might even recommend a helmet.
You like this one:
YOUR BASKET
2 x Gigabyte GeForce GTX 780 WindForce 3x OC 3072MB GDDR5 PCI-Express Graphics Card (GV-N780OC-3GD) £515.99 (£1,031.98)
1 x Acer HN274Hbmiiid 27" TRUE 120Hz 3D Widescreen LED Monitor with NVIDIA 3D Vision Glasses £299.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £259.99
1 x Silverstone Strider Gold Evolution 850w 80 Plus Gold Modular Power Supply (ST85F-G) £146.99
2 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £143.99 (£287.98)
1 x Kingston HyperX Predator 16GB (2x8GB) PC3-17066C11 2133MHz Dual Channel Memory Kit (KHX21C11T2K2/16X) £139.99
1 x Corsair Obsidian 650D Gaming Windowed Midi Tower Case - Black £139.94
1 x Gigabyte Z87X-D3H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £131.99
1 x OcUK Tech Labs Fathom All in One Custom Cooler 240mm £112.97
- 1 x XSPC EX240 120mm Radiator - Black £41.99
- 1 x Mayhems X1 UV Blue Premixed Watercooling Fluid 1L £7.99
1 x Seagate Barracuda 3TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST3000DM001) HDD £99.95
1 x Creative Sound Blaster Z High Performance Gaming Sound Card - OEM (30SB150200000) £53.99
1 x BitFenix Alchemy 24pin ATX extension 30cm - Blue £8.99
4 x BitFenix 6+2-Pin PCIe Extension 45cm - sleeved blue/black £5.99 (£23.96)
2 x BitFenix Alchemy Molex to SATA Adapter 45 cm - sleeved blue/black £5.98 (£11.96)
1 x BitFenix Alchemy Molex to 3pin x3 Fan adaptor 7V 20cm - Blue £4.99
1 x BitFenix 8-Pin EPS12V Extension 45cm - sleeved black/blue/black £4.99
1 x BitFenix Alchemy Internal Audio Extension Adaptor 30cm - Blue £4.49
Total : £2,841.73 (includes shipping : £22.20).
You can change the rings on the fans (of the watercooler) for Blue ones (they come with them i assume)..
The sound card will fit ontop of the first GPU.
Lots of blue.
Epic spec right their from my buddy Doomedspeed
I may have another go not sure tho .......
 here is a blue + silver
Well is there any way I could get like a really small SSD for Windows/Main files then one 500GB for games ? Dont wanna split my games over 2SSDs haha
YOUR BASKET
3 x Prolimatech Blue Vortex Blue Wings 120mm Fan £10.99 (£32.97)
Total : £2,874.71 (includes shipping : £22.20).
That is lovely ether.. I like a lot..
Wheres the cooler though?
I still think its 50/50.![]()
I don't need 2 kidneys, right?![]()
I swear the H100i was in the basket!!!
And only 50/50 :'(
You like this one:
YOUR BASKET
Lots of blue.
Warning on the RAM:
 I would personally wait till amd release there gpu's they are always one step ahead.**** liking the ram you have two 780's, wish I had 3k to spendI would personally wait till amd release there gpu's they are always one step ahead.
September 25th
Rhats the annoucmemt by AMD date. It won't be the release date.
No worries, i like when people use their old threads.. i stops people re-asking you questions..
I like the scheme and the parts you want.. though the 290x stock cooler is noisy and hot so i have 2 suggestion for you (pick one):
1) wait until OEM cards are released with updated (better) cooling
2) Custom watercool the build
Which of these options appeal to you most?![]()
 Unless you know how long it'll be for OEM cards and I could just build the system using current cards then add new ones in later?
