New Computer (Gaming)
It can be big, just dont like that case :P
You like this one:
YOUR BASKET
2 x Gigabyte GeForce GTX 780 WindForce 3x OC 3072MB GDDR5 PCI-Express Graphics Card (GV-N780OC-3GD) £515.99 (£1,031.98)
1 x Acer HN274Hbmiiid 27" TRUE 120Hz 3D Widescreen LED Monitor with NVIDIA 3D Vision Glasses £299.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £259.99
1 x Silverstone Strider Gold Evolution 850w 80 Plus Gold Modular Power Supply (ST85F-G) £146.99
2 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £143.99 (£287.98)
1 x Kingston HyperX Predator 16GB (2x8GB) PC3-17066C11 2133MHz Dual Channel Memory Kit (KHX21C11T2K2/16X) £139.99
1 x Corsair Obsidian 650D Gaming Windowed Midi Tower Case - Black £139.94
1 x Gigabyte Z87X-D3H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £131.99
1 x OcUK Tech Labs Fathom All in One Custom Cooler 240mm £112.97
- 1 x XSPC EX240 120mm Radiator - Black £41.99
- 1 x Mayhems X1 UV Blue Premixed Watercooling Fluid 1L £7.99
1 x Seagate Barracuda 3TB 7200RPM SATA 6Gb/s 64MB Cache - OEM (ST3000DM001) HDD £99.95
1 x Creative Sound Blaster Z High Performance Gaming Sound Card - OEM (30SB150200000) £53.99
3 x Prolimatech Blue Vortex Blue Wings 120mm Fan £10.99 (£32.97)
1 x BitFenix Alchemy 24pin ATX extension 30cm - Blue £8.99
4 x BitFenix 6+2-Pin PCIe Extension 45cm - sleeved blue/black £5.99 (£23.96)
2 x BitFenix Alchemy Molex to SATA Adapter 45 cm - sleeved blue/black £5.98 (£11.96)
1 x BitFenix Alchemy Molex to 3pin x3 Fan adaptor 7V 20cm - Blue £4.99
1 x BitFenix 8-Pin EPS12V Extension 45cm - sleeved black/blue/black £4.99
1 x BitFenix Alchemy Internal Audio Extension Adaptor 30cm - Blue £4.49
Total : £2,874.71 (includes shipping : £22.20).
You can change the rings on the fans (of the watercooler) for Blue ones (they come with them i assume)..
The sound card will fit ontop of the first GPU.
Lots of blue. :)
Warning on the RAM:
CAUTION: Users may experience extreme motion sickness and/or complete disorientation from the extreme speeds typically reached with HyperX® Predator. It is not intended for small children, the faint-at-heart, people with a lot of time to complete a creative project or anyone who settles for less. Featuring frequencies up to 2666MHz and a new heat spreader for greater heat dissipation, it’s Intel XMP ready, compatible with all popular brands of motherboards and backed by legendary Kingston® reliability. We might even recommend a helmet.
:D
You like this one:
YOUR BASKET
Total : £2,841.73 (includes shipping : £22.20).
Lots of blue. :)
:D
Epic spec right their from my buddy Doomedspeed :)
I may have another go not sure tho .......
I gave in :( here is a blue + silver
YOUR BASKET
1 x Seasonic 860w '80 Plus Platinum' Modular Power Supply £179.99
1 x Corsair Graphite 600T Midi Tower Case - Silver £149.99
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler £103.99
1 x Corsair Vengeance Pro Blue 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Memory Kit (CMY8GX3M2A1866C9B) £74.99
1 x Corsair Vengeance Pro Silver 8GB (2x4GB) DDR3 PC3-14900C9 1866MHz Dual Channel Memory Kit (CMY8GX3M2A1866C9) £74.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £47.99
5 x Alpenföhn 120mm Wing Boost Plus PWM Fan - Black & Blue £13.99 (£69.95)
3 x BitFenix SATA Cable 30cm - sleeved blue/black £8.99 (£26.97)
1 x BitFenix 24-Pin ATX Extension 30cm - sleeved black/blue/black £7.49
2 x BitFenix 8-Pin PCIe Extension 45cm - sleeved black/blue/black £5.99 (£11.98)
2 x BitFenix 6-Pin PCIe Extension 45cm - sleeved black/blue/black £5.99 (£11.98)
1 x BitFenix Molex to 4x SATA Adapter 20 cm - sleeved black/blue/black £5.99
2 x BitFenix Alchemy Molex to 3pin x3 Fan adaptor 7V 20cm - Blue £4.99 (£9.98)
4 x BitFenix Alchemy 2pin I/O extension 30cm - Blue £3.95 (£15.80)
Total : £2,885.15 (includes shipping : £14.75).
Well is there any way I could get like a really small SSD for Windows/Main files then one 500GB for games ? Dont wanna split my games over 2SSDs haha
I still don't understand why you wouldn't want to just go with a single large SSD instead of one large, one small. (With conventional storage for large media files)
It'd be cheaper cause you're not buying the second one with nearly as much capacity as the first was so much bigger than the second anyway.
The computer will be faster as larger versions of an SSD outperform smaller ones (OK, the EVO is cracking at small capacities anyway).
You should get better life as wear-levelling will be improved with a unified space.
And finally... your games would be on a single disk, which you appear very worried about. If you have the OS on a different disk to the games you'll actually end up splitting your games files as many save stuff to your user folder which resides with Windows. Yes, you can move your user folders too, but then you've split windows across disks and also some games will be naughty and will incorrectly identify which drive to use, either returning you to games on split disks or causing stuff to break.
Personally I don't care if things are across different drives and am happy to set up Junctions to redirect any programs that have poor location selection but given your stated aims your idea seems counter-productive.
YOUR BASKET
I don't need 2 kidneys, right? :eek:
You like this one:
YOUR BASKET
Lots of blue. :)
Warning on the RAM:
:D
Think I'll go for this one, purely cause I love the RAM warning (and colours :D)
**** liking the ram you have two 780's, wish I had 3k to spend :p I would personally wait till amd release there gpu's they are always one step ahead.
Apologies for reviving my old (dead) thread! But seeing as my birthday is just a few days away I've changed my mind on the computer!
Colours Black and Red
and must haves r290x and 4770k
Must run all games on ulta/maxxed out
No worries, i like when people use their old threads.. i stops people re-asking you questions..
I like the scheme and the parts you want.. though the 290x stock cooler is noisy and hot so i have 2 suggestion for you (pick one):
1) wait until OEM cards are released with updated (better) cooling
2) Custom watercool the build
Which of these options appeal to you most? :D
Custom Water cool sounds nice, however, I've never done it before! But if its easy and I can get a step by step guide ill do it:D Unless you know how long it'll be for OEM cards and I could just build the system using current cards then add new ones in later?
