NopeSD card slot?
NopeSD card slot?
Hang on, I appear to have been under a rock, there's a new version of the Nexus 7?
In a nut shell, why should I upgrade from my current 16GB first Gen 7?
still not got my R update yet- so much for getting google updates quickly!
Has already been answered a million times, but the answer to your question would be the screen. The resolution, viewing angles, colour accuracy and contrast, is just immense for a £200 device.
.Hang on, I appear to have been under a rock, there's a new version of the Nexus 7?
I discovered Swype yesterday...OMG what a revolution in typing, I've been missing out on on my iPhoneIt's fantastic!
3. If you long press one of the touch sensitive buttons (the menu one I think) then it should come up with a list of all open apps. There is a trashcan symbol in the corner, just press that
Nope no trashcan.
Netflix is so awesome on this tablet. Looks so much better than it ever did before, the image quality is very crisp for streamed content.
if your talking about the recent 8MB update, then stop getting your knickers in a twist, it adds nothing and is most likely just a kernel tweak.
I bought an 2nd gen today from Currys, I happened to ask what happens if there are any dead pixels, the shop assistant said they dont take returns for dead pixels unless there's more than 5 in a square inch.
I asked if were could test it there and then which i thought was a reasonable request, he said "No, you need to buy it to open the box, but you can't return it if there are any", less than impressed I bought it, luckily there were none.
