yes I did that..Is it ok to install 8.1 on top over win 8?
Yes,basically use one of the keys above to install Win8.1 RTM (depending if you have core or Pro version key)then after install at desktop change the key by installing your upgrade Win8 key,ie use command prompt as admin, type
slmgr.vbs -ipk xxxxx-xxxxx-xxxxx-xxxxx then hit enter key
xxxxx-xxxxx-xxxxx-xxxxx being your Win8 upgrade key.
It does work that's how I did my clean install of Win8.1 RTM Pro with my legit upgrade Win8 Pro key.
Thought the built-in AV stuff from microsoft was adequate?
Are other peeps running seperate AV programs with their Windows 8 installs?
"Windows 7 is six times more likely to get infected than Windows 8 and Windows XP is 21 times more likely to be exploited."
But that was still all defensive reactions; for Windows 8.1, he said, Microsoft is going on the offensive with better malware protection, new ways of checking the security certificates web sites rely on - and with a plan to add encryption and biometric security to every PC.
Windows 8 security explained
The built-in anti-malware tool Defender will protect against more threats in the browser, including from plugins and ActiveX controls. "In Windows 8.1 we will scan those payloads before they're executed," Hallum told us.
Whats wrong with Avast 8 on Win 8? Seems ok here.
Avast 8.0.1497 Now Compatible With Windows 8.1
If you decide to try this on your 8.1 computer, please be advised of the following:
On boot, you may receive a warning indicating that Avast 8.0.1497 is not compatible with Win 8. The Avast response to this issue is:
we fixed all issues with Windows 8.1 however we are waiting on Microsoft to remove the BLOCKs for avast Antivirus. That's the reason why you still see those warnings.
The temporary solution is to check the "don't show this notice again" box when prompted.
You may also see a few event logs because of the above situation. Specifically, I am/was receiving an Event ID 1 and I also received an Event ID 1000 log initially but now it appears to have vanished.
In any event, I'm glad Avast is back for Win 8.1 and the first thing I noticed was the marked improvement in boot speed. The Windows Defender boot processes must have been slowing down my laptop boot dramatically.
Get it here:
I always use Kaspersky Internet Security and I will continue to use it because I've never had a virus/malware get through itThought the built-in AV stuff from microsoft was adequate?
Hi all,
I'm glad to announce that we've just released AVAST 2014 BETA2 (build number 9.0.2001).
Many thanks for all comments you provided us here on the forum and feedback.avast.com from the first beta!
We've fixed many problems, here is the list of the most important ones:
- GUI glitches
- FW stability
- Network protection component tuning & compatibility (Win8 ) - no more Tdi technology
- Windows 8.1 compatibility
- Smooth updates of VPS & program
- Updated the SafeZone browser
yes I did that..
but I went back to windows 8 due to Kaspersky Internet Security not being compatible with 8.1 yet.
 So I will wait till public release.yes it's RTM.Hi all, I have installed ISO from below link and on the bottom right is shows Windows 8.1 pro build 9600....are we sure this is RTM and if so how do I get rid of that build information?
yes it's RTM.
you need to change the key to your own key then it'll activate
Ok great so then it will get rid of build number stuff...cheers
Windows 8.1 Pro
Secureboot isn't configured correctly
Build 9600
Mine is activated and I still have the build number in the bottom right corner. No idea how you get rid of it ?
I have
In the corner of mine.
Anyone any ideas how to remove. I do not have secureboot enabled as my GPU does not have a compatible bios.
