Caporegime
- 18 Sep 2009
- Dormanstown.
DELETE
These are the comparison tables from the leaked review which show 30% gains over various cards.
SOURCE
Anyone going multi gpu would need to run 6core cpu or more.
Just ran this
4 Titans @stock
3930k @4.6 using only 4 cores and 8 treads
v the best 4 card result for a 4770k
4 GTX 780s
4770k @4.6
http://www.3dmark.com/compare/3dm11/7210231/3dm11/7210132
What is interesting is the 4770k beat me slightly on graphics score even though I came out on top in all but one of the tests.
With overall score I came out on top even though I was only using 4 cores.
The point is I can also over clock quite a bit higher than the 4.6ghz used here.
4770k setup
http://www.3dmark.com/3dm11/7210132
My setup
http://www.3dmark.com/3dm11/7210231
I was not expecting my 4 cores to win on efficiency.
There are a few Haswell results using 3 cards that score slightly higher than the 4 card result here.
These tables are not showing performance gains over cards. The first 3 are showing how big a hit each card takes when adding in aa so lower is better. The last 3 are showing how big a hit each card takes when moving up to a higher resolution so again lower is better. The results clearly show that the new amd card takes less of a hit.
Ah I see what your saying, it could very well be that you are correct and that is what these charts are showing, it does seem to be a completely useless set of charts if that is the case. A chip that is 8 months newer uses roughly 2% less grunt to apply AA or increase resolution, whoopy doo.
So looking at the other charts in that review is thereabouts a 10% lead or more would you say?
We pretty much know the score by now, it would be more impressive if you called it back when we didn't even know the chip name.
Right im throwing my hat into the ring. Titan beating performance at $550+. You heard it here first folks.
I still don't get why it's being compared to a card that came out 7 months ago, that's a long time in the tech world. Comparing it to a 780 is sort of ok but still they've had 3-4 months to make sure it beats it. I'd actually be very surprised and disappointed in AMD if it didn't.
So before these leaks, people were saying it wouldn't be able to beat a Titan and might not even match a 780. Now after the leaks, people are saying the Titan's so old, it's nothing special beating it.
If this comes in at £450 or thereabouts and bumps the titan off the top spot as the fastest GPU, then AMD gets all my respect for not robbing the consumer. Priced over £500 and I won't be to ecstatic.
anyone else going to be scouring the MM tomorrowhehe
I think people will be amazed if it beats out a Titan because the titan chip is 30% larger and we are still on 28nm. Titan also cost's you a small fortune for the pleasure of owning one where as this card should be half decently priced when compared.
