I wear his khaki shorts.
Not good timekeepers from what I hear.
don't pull it out
Power reserve of what 42 hours~? After 7 hours, with power in reserve it should have plenty of power in the spring left. Nam's sounds like it's just not been wound up fully yet and lack of movement over a day's wear isn't enough to wind it. May need many more turns. I've seen people report 60 turns for theirs. Depends how low it is I guess.
I wear his skin like a onesie. By we digress...
Don't pull the crown out, just wind it clockwise (usually) until you feel it stop. Do not force it if you feel resistance (back off topic again!) or you'll damage something.
Side by side, build quality is very close and the biggest difference is the watch face of the Omega being pure/darker black and thus makes the glass seem clearer.
It’s not like I could see the inside and can comment on how they are![]()
I think the Omega is nice, it is very nice indeed but if I had to put a number on it, is it 10 times as nice?
I don't think it is 10 times better built, it certain doesn't keep time 10 times better, or it certainly doesn't look 10 times as nice but the last part is subjective anyway, but then again they are both divers and to the lay person they are all the same apart from the name.
So taking away the name. Both having Sapphire crystals, stainless steel, (I can get a ceramic bezel for mine easy enough) both of almost equal weight in hand, they both feels the same when on the wrist to me. The difference is in the innards, but the Steinhart has ETA movements, not some Chinese knock off (hence the waiting list on their website), also the back of the watched is not see through so I can't appreciate it visually which sucks, part of me wants to see it, if spending so much money on it, much of it for the internals.
The things I like on the Omega is the darker watch face, the glass seems and look more transparent.
The marker at the top on the Omega is inside the triangle, that I like, and I like that it is flat, The Steinhart's market is dome shaped and goes outside the triangle.
I am not a fan of the bracelet on the Omega, prefer the one on the Steinhart.
Overall, taking everything into account, I am happier having the difference in my pocket than spending it on the Omega.
With regard the Seiko vs. the Steinhart. Is the Steinhart worth double the cost of the Seiko?
Yes, I think so. Picking it up you can see which one is more expensive than the other.
The Hardex crystal on the Seiko although hard when you tap it, it looks like clear acrylic plastic rather than glass.
The Seiko's bezel doesn't click as loud (the Omega is very pronounced when you turn the bezel), it is also easier to turn with minimal force on the Seiko plus it has a tiny play before it clicks to the next notch.
The brushed finished on the Steinhart also seems more rugged and hard wearing than the polished finished on the Seiko. The strap on the Seiko is also thinner, and the pins to remove the chain are not as convenient compare to the Steinhart. So, yes, it is worth the £150 difference.
Veblen goods arent ever going to tangibly worth their price differential over micro brand homages, the same principal applies to designer anything, handbags clothes etc.
They are desirable because they are expensive essentially.
Wouldn't that be the dream. To commission the hand build of your own custom watch by a watchmaker somewhere in the Swiss Mountains?
I'm sure there are people with serious money that actually do that and it's only known about to those close to them.
