Considering the Optimus G (Nexus 4's twin) is still on 4.1.2, I very much doubt it.Would the G2 get a kitkat update soonish?
32 GB internal storage or MicroSD card support or I'm out.
It seems to get good reviews
The bezel and dimensions should be very similar to the ZL:
- design might look nice but when using their devices they are uncomfortable, sharp rectangle slab just doesn't fit nicely in the hand (at least for devices that have a screen bigger than 4.3"...)
Keeping my eye on this one, I have a Lumia 800, lasted well but despite it being quick, fluid, easy to use, I'm missing out on some apps all my pals use for pic sharing etc and are all iphone or android users
I assume this would be a worthy upgrade to my current phone? I tend to keep them 24 months.
but then it won't be nexus 5.. so you're saying that releasing a newer yet less powerful phone is the right thing to do? not in my opinion.. 1080p displays are beautiful![]()
Androidandme are reporting that the Nexus 5 doesn't share the same camera as the G2, the leaked log file is indicating a 8mp camera and not 13mp.
Now, I know resolution isn't the be all and end all of the performance of a camera, but I'm concerned we're heading for a let down again in terms of camera performance. At least we know the G2 sensor is capable.
