Unigine Heaven 4 benchmark
Man of Honour
OP
21 May 2012
Dalek flagship
7970@1200/7200
i5 [email protected]
And on the scoreboard.:)
22 Nov 2010
mine seems low when comparing to others on the 7850 thread and this thread.
how is it so much lower when i have the same card?
edit: my bench settings were wrong. even worse now.
28 May 2007
Your score is fine. This is the score from the top 7850 in this thread.
Score 717, GPU 7850 @1240/1500, CPU 2500k @4.4, vfdb
As you can see he is running higher clocks than you on the gpu. He also has a better cpu so that would play a small part as well.
Caporegime
14 Dec 2005
armoy, n. ireland
Right, still cant get a screen grab via afterburner, (maybe down to the latest nv beta drivers). Just had to take a pic of the result on my phone. Bit blurry as im drunk and the nokia lumia 620 has a poor camera.
Please keep images to below 1280px wide or post in
tags like I've done for you above - Rilot
Yes, flash was on on the phone cam, gpu clocks of 1267/1228 core, 7504mhz memory. Cpu @4.5ghz, 42x uncore, ram at 2133mhz 9-10-10-21 1T cmnd rate. Apologies for the size of the image.
