You should be fine I'd imagine. I was running it on high settings on a single 6950 unlocked to 6970 in the bios.
I only saw some slowdown a couple of times and from reading around it seems like the beta drivers and later builds might eradicate that.
SLI on = 15-20 fps, Stuttery as ****
SLI off - 80-100 fps, Smooth as butter
On 331.40
No ^^
So I'd need to buy from EA then I'd guess to get in the beta?
If so it can wait I'm not in that much of a hurry![]()
more with sli off - single 670? ooo![]()
Aye :/ Truly unplayable with SLI enabled.
all pre ordered with simplycdkeys bargain![]()
Mine crashes after a while too, although i did notice theres a new Nvidia driver. Thought it might of been due to PB at first but I cant even update that as it's not in the list of available games.
Anyone else have frequent crashes?
Where do you turn it off? Game settings or nvidia CP? If latter, how?
pb isnt even on in the beta![]()
