what happens if you have a start button replacement installed when you do the update? does it stop functioning?
seems to be an issue now with win store.
i downloaded a game and the new fb app. neither show up on my start screen, and when finding them in winstore they say they're installed but no way to then open the app, and i've since uninstalled the fb app amongst overs but they still show as installed. bit lame
Does it still come with create system image ?
According to HowToGeek:
"With Windows 8.1, these deprecated backup tools are no longer present. Windows 8.1 still allows you to import backup images created with Windows 7, so you can access your old files, but you can’t create a Windows 7 backup or a system backup image anymore. The advanced startup options menu no longer includes a “System Image Recovery” option to restore from a system image.
If you want to create a system image backup or restore from one, you’ll need to use third-party backup software."
Can you actually get them to download though? They keep getting so far through than I get a fatal error, even when using the download manager.They're on my VLC
From here http://www.hdwallpapers.in/digital_universe-desktop-wallpapers/page/3 ,plenty there.
I'll tell you what has me stumpted.
I have a Windows 8 laptop (It's an OEM, has UEFI, the Serial is like hard coded into the laptop)
It's running an 8.1 Preview ISO.
Do I need to install an 8 ISO on that first to then put it into 8.1 or what? Can I install an 8.1 RTM ISO on it (With the UEFI hardcoded key?)
What about my Surface RT? That's running an 8.1 preview, how will that work (For all the none really tech people) will it just turn the preview into 8.1?
yesWait, so I can't just grab the new 8.1 iso and use my current key to install?
Where do I get an 8.1 key from then?
Or do I have to install 8.0 then upgrade to 8.1 (faffy).
