Updated Mail app is much better now, pleased with that.
Can't quite get used to have that Start button there... feels weird since I haven't missed it for the last year.
Wait, so I can't just grab the new 8.1 iso and use my current key to install?
Where do I get an 8.1 key from then?
Or do I have to install 8.0 then upgrade to 8.1 (faffy).
According to HowToGeek:
"With Windows 8.1, these deprecated backup tools are no longer present. Windows 8.1 still allows you to import backup images created with Windows 7, so you can access your old files, but you can’t create a Windows 7 backup or a system backup image anymore. The advanced startup options menu no longer includes a “System Image Recovery” option to restore from a system image.
If you want to create a system image backup or restore from one, you’ll need to use third-party backup software."
This is downloading so slowly and I have no idea at what speeds. Going to take a while.
Interested in an answer to the above myself
Just finished updating the missus' Acer laptop.
Touchpad driver ain't working, but my biggest bug bear is YTF does it need to leave behind a 3Gb Windows.old folder that I can't delete!! - grrrr
The only real problem I encountered was my Creative SoundBlaster Control Panel is not working
