Unigine Heaven 4 benchmark
clock @ +180 Mem clock @ +600. power limit 106%
Just installed my second 7950 today. Not sure if their stable in games yet but they ran Heaven without crashing. Think I lose a few fps due to my motherboard (Gigabyte Z77-D3H) not being PCI-E 8x8. Am I in the right ballpark?
Should add i'm using LtMatt's new bios on both and 13.11 Drivers.
Your cards are working fine and it is a good score.:)
And on the scoreboard.:)
Seems very reasonable looking at the score board. I've noticed the newer drivers are helping with scores :)
reference card Msi gtx 780 gpu core @ 1202 Mem core @ 3602
i7 3820 cpu @ 4.75Ghz
cant sqeeze a drop more out of it with out it crashing half way through everytime at +196 on core. Would water cooling help? although it didnt go past 72c at 100% fan
You already have a good score for a GTX 780. Water cooling can help but don't expect huge gains with a stock card, you may be able to overclock by another 13mhz or so. What is nice about using water is running the cards in the 30s rather than the 70s.
Are you using PCI-E 3.0 this is also good for a few more points.
I shall give this a run Kaap (even if my new monitor has light bleed). I want to see if my Titan is as fast as Matts 7950's, so come one Matt, get it done :p
