Caporegime
- 18 Oct 2002
Watch the video - even under normal loads its significantly noisier than most other cards.
AMD really do need to work on those reference coolers/sheaths.
In non Uber mode it's barely louder than anything else and no louder than a 7970, in fact seemingly quieter despite increased performance, power and core size. uber mode often gives zero performance benefit, it's mostly silly and pointless. Even so the difference between the uber mode and 100% was absolutely monumental so talking about 100% fan being relevant is daft, it's not. Under neither mode will it get anywhere near 100% fan or that noise, not ever, not even remotely close.
Will AMD ever get the fans right, always so noisy I wonder why they even release the stock models![]()
Again in quiet mode(which sacrifices between 0 and 3% performance on average I would say with only a couple games showing 5%) it is incredibly quiet, what you can physically set the fan noise to, that it doesn't get anywhere remotely close to in any even heavy use situation is completely irrelevant. You have to go out of your way to make the card that loud. It would never hit that noise under any game, nor furmark. Here's a hint, most fans if you put enough power into them can make that noise, where it's actually used is the only relevant information. It's quieter than a 7970/680gtx in use in normal mode, which are pretty quiet cards.
