- 5 Sep 2011
- Surrey
Just get a huge side intake that always keeps gpu temps down
I added a side intake fan for my GTX480 ....
my temps went up
I tried it as an exhaust - my temps went up
so re-blocked it up![]()
I guess I get rid of all this water cooling nonsense and back to Air cooling and never the need to take the side of my case off again
That can't be you case Greg, It's all mint and pristine, with no sign of half the carpet blown in from the auxiliary benchmark fans...I'm impressed, that's a credit to yer
I've found that having an intake bottom fan helps a lot - the cool air is pulled up from under the case, hitting my GPUs,
Yup, you got that right, a big filtered 140mm in the bottom of the case even ducted right up the chuff of any Blower type card works wonders
personally I still much prefer blower type coolers for GFX cards, the downside is you just can't get them as quiet if you want low temps![]()
But I need to get the rads and pipework outside the case for better airflow apparently
Sorry Humbug but like I said originally, I take the side of my case off and it drops the temps by a couple of degrees. I wasn't looking to be told where I was going wrong but thanks for taking the time to help![]()
Apart from being a pita/expensive when you want to change components, yeah![]()
Why do people care about the temp, at all. Why is it okay for an Intel cpu to run at 80C when an AMD cpu runs at 65C, people move from AMD to Intel and you get threads of "OMG, wtf, my cpu is burning up, the house is about to explode, if I was at that temp I'd be dead".
