So in quiet mode the 290X is only 1db louder than the 780. That doesn't seem too bad to me. I'd probably run it in quiet mode if i had one and user uber with fan at 100% (jet engine) for benching.
Lol, Oranegy!
could the 7970 not sit at 95C ? without throttling
so why the fuss about the 290x being designed to run at 95C - most modern GPU chips do that can't they ?
so why pick 95C for this card and not the 7970 ? or is it the lowest they could get it without the fans being annoying ?
Sorry if this has been mentioned before but is the switch physical or software?
7970 was built to operate up to 90c at stock speeds. However if you were overclocking you had to keep it below 80c. Larger overclocks below 75-70c. Extreme overclocks often 65c or lower.
I think it is absolutely fantastic that the R9 290X can hit 95c and handle it.
What this means to me is I can fit the waterblocks I have on order, run the cards @35c and stick lots of volts through them without having to worry about overheating.
And this is what I will be playing when benching four R9 290Xs
Where from?! Any hints?
Never mind, found it and ordered one too!! Thanks for the heads up...
At that price it's impossible not to buy even if there'll be a long wait - Arctic Cooling might have a new cooler out by then too.
The biggest thing you forgot was the 480 was very late and when it did eventually release it was still broken
one of those after market air coolers when they release should sort the heat out
GTX 780, R9 290X... whatever, just buy what you want and enjoy?
Honestly, all the passive-aggressive smiley usage is just embarrassing. 7970, 7950, R9 290, R9 280x, R7 270, 7990 or R9 290X... whatever, just buy what you want and enjoy?
 I jest. I've used both for donkeys years, I won't buy a 290x(for now) as on my budget £315 I paid for a 7970 ages ago is about as far as I can stretch and with 20nm chips potentially well under a year away I feel a £400+ chip has a lot less value in longevity than say the 7970 had.
