- 19 Oct 2002
- Torbay, Devon, UK
Im clocked to 4.4
Im clocked to 4.4
Lets hope BF4 is better. lol
LtMatt have youdone a recent Heaven 4 run.
As I have just beaten your score.
Hey Matt.. if i crossfire my current Sapphire Dual X 7950 which do u think is the best 7950 to do it with regarding heat? Reference card or similar to what i already have?
My case cooling has 2 front 120mm intakes (can fit another 120mm in the bottom of case if i want) and 3 outtake 120mm fans.. 2 up top and 1 out the back.
Cheers![]()
I'd go with an Ice-Q if you can. Or you can get the same card as you have now, but you'll need a side exhaust fan or two ideally if you go with two gpu's that dump heat in the case.
Yea i got space for a side fan if needed.. its a Zalman Z9 Plus case.
LtMatt what are the volts set at on the Bios. Mine are showing 1.150, thought it was 1.175.
Thanx
Done that rebooted and still showing 1.150.
