What clocks did it reach on the stock cooler again?
1270-1300 depending on the bench with 10-15c ambients and a fan blowing on the back of the PCB. RAM will do 1880 anyways.
To do 1370-1380 1.384v on water i need 28c load temps or under. If not i will stutter or artifact into a crash.
Am I reading that correct - 28c load temps with just a 1080 rad
http://forums.overclockers.co.uk/showpost.php?p=24028168&postcount=79
34°C @1325/1900 1.384v at around 20-21°C ambient with 360/240 rads. Yes, they're Monsta rads, but they're not that much better than most decent radiators and are also mounted in the case rather than externally.
My card just isn't the greatest clocker, but I'm not really into benching tbh.
Your 1080 rad is very nice and very capable (even being 'only' 5fpi), but it's not the defining factor IMO![]()
Your card's clocking ability and the low ambient temp (if that's still the case with your bench results) allied with the rad being external has more to do with it.
. Even on water.You are reading that correct, i need 10-15c ambients though to do it.
Thanks
I only bench with 10-15c ambients. Even on water.
Yea im confused too, why are you thanking me? hahahah
For the info
Remember, i cant do it with normal ambients. 20-25c or so.
I was asking what cpu he was using and if he had overclocked it out of curiosity as for all i know he is using something on stock. My following question should he answer would have been what his CPU temps were like. In my post i commented that i was trying to work out how many rads i need and never stated that i was confident it would be enough. I was asking because i don't know what i need and tbh was expecting some constructive advice not some useless comment.
I'm not looking at benching etc although i will do a bit
Looking to get a 290 (non x) and put it in a loop with my 3570k, do you reckon a 360 and a 240 will be good enough for that?
