- 5 Sep 2011
- Surrey
That Sapphire product code is a 4GB 290. So yes, it's a non X version. That's a bit of a **** up! Call them...
Get some benchmarks run you'll be famous, try to find out how many stream processors it has etc.
well i ain't very happy, paid the price of a 290x.... will try some 3dmark before sending it back.
This, your name will be plastered all over the net, R9 290 review, before NDA release! Go....![]()
primouf what is the order number for this please? I cannot see any orders on our system under your email you registered on the forums with.
don't have much time at work but will test tonight !
here is a go on 3Dmark basic edition, don't have extreme sorry.
http://www.3dmark.com/3dm/1515052
13.11 betav6
everything stock,max temp 94°c ventilation max @ 40% ( not much noise i must say )
some coilwhine during the first half of the tests.
Huge sighs of relief at OCUK.![]()
10k is impressive, what's the rest of the system?
(if you ment the one with the R9-290 result)
