- 25 Mar 2004
- Fareham
LtMatt wondered if maybe later on you could give me a quick hand with my cards and a bios update on them? I added you on Steam!
Q for you guys, i must have messed up on my optimized bios and set the power limit wrong
and im throttleing,
what settings do i put in this picture ??? so that i will get no throttling at all on the card...
even with any overclock.
these must be the default power settings of the bios, what settings do i put so i get no throttling at all
EDIT: never mind i just ripped out a bios from somewhere else and read it for correct no throttleing power settings
173 it is![]()
If you have any questions fire away. I already wrote a bios flashing guide for these cards here.![]()
Think I got it! I was getting throttling in games where the cards were lowering core speeds, I applied your bios Matt.rom from the link to both cards, set the power % to +30 in afterburner and since then everything is running much smoother, usage in Crysis 3 after an hour or so showed I was getting high 90% most of the time with few dips.
Temps and Power draw seem lower as well (I have a wall plug that monitors power usage, before the bios switch I was drawing about 525 watts for everything, afterwards I was using about 425. Before the switch I would hit up to around 83 degrees as well with only 65 degrees or so after.
Is that because the default BIOS draws more power by default?
Thanks LtMatt!
What in your opinion would be an easily achievable 24/7 clock for these cards? I don't want to push the limits really but a bit of extra performance never hurts![]()
Easily achievable should be 1100/1500. At that speed you're matching 7970 ghz/280X at stock.
my card will no longer do more than 1000/1400 stable across all games. Why would that be?
It used to play 1250 / 1600 fine but has slowly degraded since I bought it a few months ago.
That sometimes happens in the Tomb Raider bench, its a bug i think. It never happens in game. Sometimes its fine though, just seems like luck of the draw. As for crysis 3 not sure on that, didn't see any when i played it. Is this at stock or overclocked?
Recommended tests to run sir to check the stability?
