Caporegime
- 7 Apr 2008
- Lorville - Hurston
Mine hasnt moved status since i ordered it two days ago
Mine hasnt moved status since i ordered it two days ago![]()
mines out for delivery today!
excited much?
OK, after an evening with my 13" RMBP, I don't understand why the 13" Air exists.
The 13" RMBP is 1mm thicker than the Air (at it's thickest point), 14mm wider and 27mm deeper. It weighs 490g more.
Hardly a big difference, but it's much more powerful, has a much better screen and is only £150 more expensive.
The screen is far superior to the MBA imo.There are a few valid reasons why you would go for the Air instead of the Pro:
Quite frankly though, the majority of people who have the money to spend will probably be happier with the rMBP.
- Slightly longer battery life (the difference isn't massive but may be enough for some). No idea about the projected numbers but if I'm just taking notes battery life on my Air is well above 13 hours.
- Blurriness at scaled resolutions on the rMBP. Many aren't bothered by this, but those that are (including me) find this horrible - my eyesight is bad enough!
- The difference in form factor and weight is slim (pun not intended), however if you carry the device in a thin sleeve the MBA will still feel quite a bit thinner. Not something that would cause you to buy one over the other, but potentially a "bonus" in addition to the above points.
- The £150 difference simply isn't worth it if you don't see the benefits of the rMBP! CPU performance is very, very close too.
Mine didn't move for 5 days!
Gave them a call and their systems are down, and they can't find my order online.
Hoping that its all ok. I ordered the top spec 15" on the 5th just before I stopped working for Apple. Will be seriously miffed if something has happened.
Apple says estimated delivery is Weds for mine but UPS says by end of day Tuesday, hopefully UPS are right.
It's in the country already and had departure scan so Tuesday sounds about right.
